Is anyone using Sygic GPS Navigation on their FP2?
After the latest update from Sygic it just crashes whatever I do (reboot, reinstall, moving between SD & local storage).
I’ve used Sygic a lot on my previous phones and I’m reluctant to ditch it and look for other navigation apps…
Thanks @bfb and @ivi !
I finally got the new version to work by uninstalling, then manually deleting the Sygic-folder, and finally reinstalling.
It’ll be interesting to see how it performs on my FP2. On my old phones I rarely had any problems with the GPS signal strength…
The speed limit display I’ve never found trustworthy in Sygic - sometimes it shows and sometimes not. And when it does show, it’s often the wrong information.
But apart from that, I think Sygic is the best offline navigation app, I’ve used it a lot both in Sweden and several other countries.
Hi All
Just wanna clear my opinion…
The GPS Modul in FP2 is very fast and strong,
I have always after sync starting within 5 sec until max 30 sec a great fix!
I mean, the catch of gps position.
I only use the gps modul without Network or mobile Data position help!
@ bfb
This kind of problem never appear on my FP2 with sync 15.x.x
