Is it possible to manually switch between the wide and normal camera lenses? I have both the default camera app and OpenCamera, but I don’t see such an option.
Or should a camera app switch automatically?
My FP4 has Android 11 and the latest March updates.
Welcome to the community
In the stock Fairphone Camera app you can change lenses with the buttons on the right:
Thanks,
How exactly does it work, any zoom value smaller than 1 activates wide angle and larger than 1 is normal?
Pretty much, yeah, but if you don’t use zoom (like I do) you can just use the [<->] button to change to the wide angle lens and 1.0X to change back to the regular one.
