Hey,
I have just updated my E os and wanted to reapply root. So I did the usual of downloading the boot.img, patching it with magisk, then booting it with fastboot and then rebooting.
Everything went as planned, but the last step. Here in a bootloop, that I am unable to recover from with my knowledge.
My current situation: I try to start the phone, usual bootloader is unlocked message appears, then it goes into booting e os.
I tried to get into the fastboot mode by pressing volume up and power button. With this I sometimes got into a mode where only some charing symbol appeared and my pc said that some device appeared, buut neither adb nor fastboot are able to recognize the device.
Then I read I am supposed to get into fastboot mode using volume down + power button but with this I got nowhere.
The fastboot mode on the FP4 is reached as described here the button combination you mentioned would not work as far as I know
Alternatively, you can disconnect the USB cable, turn off your Fairphone, then connect the cable and hold the volume down button. After a few seconds, you’ll see the fastboot mode.
Thank you for pointing this out. Definitely going to look into this. Got a little spooked.
I learned a lesson and started with making a backup though
I also think I know what happened. I think I flashed the wrong boot.img which was incompatible. I had the e/os version 1.5 on the phone but used the boot.img 1.5.1 by accident.
