Stains on white protective case for Fairphone 6
The white case for the Fairphone 6 seems to have a surprising issue: it stains more easily than any other white object. After just two weeks of normal use, the corners of my case had already turned blue from clothing dye, and the sides developed a yellowish tint (and, yes, I DO wash my hands).
Removing the discoloration seems impossible. I have tried dishwashing liquid, soap, alcohol, microfiber cloths, and even chlorine-based cleaners, but none of them worked.
Does anyone know an effective cleaning method?
Without a reliable way to remove these stains, the case becomes practically unusable in a professional - or any - setting.
A similar (though less severe) issue has reportedly occurred with previous models as well, and mine seems not to be the only current case.
Still, these might be exceptions — has anyone else experienced the same problem?
I was thinking getting the original white case for my white FP6, but this sounds concerning.
For my part, I find the dark green (“forest green”) accessories look fine on a white FP6 (and probably will be more esthetically forgiving with tear and wear). Some photos of that combination here.
That is so true, mine got way darker than the time i got it, good thing that i bought the black one too :grin:
I love black on white…
Yeah, the same came to my mind. I might get the black case instead of the white.
