Does anybody know a speaker system that can be connected to FP with a cable? If I understand well, any speaker system using bluetooth can also be used, right?
You can connect your FP to the speaker system through a cable, like one of these (make sure it has 3,5 mm). The assumption that you can use bluetooth is also correct!
Er, any speaker system having a cable to connect to?
Maybe I didn’t understand your question properly, but I don’t really see why a wire-connectable speaker system wouldn’t connect to the Fairphone via the earphones plug
You are right! Sometimes, the mind confuses more than it helps! I realize it is of course possibel to connect through the earphones plug… what can I say… thank you!
Glad this became clear now.
This topic is now closed. New replies are no longer allowed.
