Sound problem with Wechat
Hi there
When using the video chat of Wechat, the sound is really low, even with maximum volume. If I plug my headset in, the sound becomes very very loud, and impossible to put it down…
Well I hate Wechat and it’s full of bugs, but I didn’t have this issue with my Huawei before, so I guess this might be related to FP2 disfunction ?
Thanks for support.
Sorry you didn’t get an answer for so long and I can’t help you much either, but I can bare some good news: In the beta section a release is being tested atm that is supposed to fix this issue!
Fixed low audio volume when using WeChat’s speaker mode
quoted from the changelog
Thanks a lot !
Looking forward the next Open OS version to solve this.
The update has just been released (see below). Does it fix the problem for you?
https://forum.fairphone.com/t/fairphone-os-1-5-1-is-ready-to-download/19873?u=johannes&source_topic_id=19259
I’m using Open OS 16.06.0 and just checked the updates. No update until now.
Open OS is always a bit behind.
The new update solved the problem. Good job guys !
