I just did, both microphones won’t work on the myFairphone app. They work, though, when I record a video in my camera app, so it seems not to be a hardware issue.
Thanks @EddieB
Do you know which FP5 release fixed the problem?
I’m trying to get this fix moved over to CalyxOS.
@nereocystis Hi Kevin, I have Android 13, Security update 5 March 2024, a huge long Kernel version, Build number FP5.TT4C.A.154.20240320, if that helps. I’ll try to add a screenshot.
Thanks so much to whomever fixed this, lifesaver
I have the same issue. It is not resolved for mi. I cannot practice speech in Duolinguo. I tried updating the phone uninstalling and reinstalling the app. sill not working. in busuu inside the lessons it doesn’t work either but at in end of them in practice yes it does. I really don’t understand. Is there any solution?
Have a look here
