I agree, none of the OTA updates lock / unlock critical partitions.
Calyx for example uses the OTA update mechanism in fastbootd (fastboot in userspace) to flash some of the partitions during installation, critical partitions are still unlocked on my phone.
And the recent Fairphone OTA didn’t lock critical partitions on the other device I have access to either.
So for @Volker locked stays locked and for me unlocked stays unlocked, I’d say case closed
Edit: I just stumbled upon this bit of information in the Android docs:
OTAs should fail to update critical sections if the device is in lock critical state.
Maybe this depends on the OTA as well, I’m not even sure OTA updates generally should touch critical partitions?
According to the docs:
devices shouldn’t ship in the unlock critical state
So if critical partitions are locked from the factory and OTA updates shouldn’t update them, are they even supposed to be changed apart from flashing factory images?
Would be nice to know which of the partitions are critical partitions, the normal system partitions mentioned in the docs probably aren’t and the part about critical partitions doesn’t offer much more information
Probably anything that’s loaded before the system is booted. If we use this (old) blog post as a reference, that would mean abl, xbl & Co.
