I can connect via the fp2 hotspot but get no internet.
I get this on my iPad ERR_NAME_NOT_RESOLVED
What’s wrong?
Any help appreciated!
Sounds like DNS is not working correctly. When trying to resolve a name to an IP, the Pad doesn’t get an answer.
Some things you may want to check:
- Can the FP2 itself connect to the Internet successfully by using mobile data (not WLAN)?
- Can the iPad connect to the Internet successfully by using a different access point than the FP2 (not mobile data)?
- Does either the iPad or the FP2 run a secure VPN/firewall app that might prevent data traffic?
Okay, but what can I do about it?
That is Yes, Yes and no.
What am I to do?
Best, Herbert
Try to delete the WiFi hotspot from your iPad and reregister the network afterwards, then connect again…
Hi, well I did a reset to standard settings of my provider and suddenly it worked!
Now I’m okay!
And thank you
Best, Herbert
