Nice
Now letās see if that fixed the stock install process or if we still need to fix something elseā¦
The phone booted successfully.
Man, you are a savior! You have saved me so much truble. Thank you for your incredible help!!!
Awesome
Iām really happy for you this worked!
Thank you once more :d Im so happy
I cant be thankful enough.
THAT'S GREAT!
Good job both of you, patience and determination on both sides, and expertise on one, and growing on the other. In my old rƓle-playing days this would earn you both a lot of points
Thank you That is kind.
Nice story! I enjoyed following you in your efforts and Iām happy it ended successfully
This is actually interesting. I did not install iode because I presumed you couldnāt get rid of microG at all.
But if youāre telling me you can somehow uninstall it during first run wizard, then maybe there is a way to get Gapps on the rom after all.
I recently ran over project ālite gappsā which appears to propose a Magisk flashable gapps suite that you can install on an already setup system. Now I donāt know how stable this is, but it could be worth trying.
I have tried it, it cannot even launch Play Storeā¦
Server connection fails and retrying forever. The others are also not working, i cannot set up my whatch because it quits. I think because of the package not functioning properly, i have tried to hide magisk but that did not help.
Hmm. I trust you tried both lite and core version without more success ?
Of course for it to work, MicroG has to be uninstalled, otherwise there is no way to get this working as I understand it.
I have tried the plain core and the ++. It does not work, when start the phone it says that i cannot use the x application without google services⦠I try now to download as apk
I have of course not installed microG, i have unticked it
Now it tries to log in into google play but it is stuck on Daten werden ueberprueft
Hmmā¦
Unfortunately, I havenāt tried to get it working on my side either yet⦠There are chances this doesnāt work on every roms⦠Have you tried playing with the lite gapps controller I recall it is a command line tool to use with the terminal that will allow you to install various additional google services
No I have not tried it but im a bit noob for that yet. But I google a bit
And next time please just use fastboot resize-logical-partition <partition> <size>
and donāt touch the actual partition table.
https://source.android.com/devices/bootloader/fastbootd#fastboot-commands
I will not, i promise it I have learned from this a bit.
Lol i cant believe it xD I have downloaded with the controller all the missing (almost all) services and it just works.
Thank you very much
