Okay. But for name should i than type the original (5 - keystore) or the msftdata? Msftdata, right?
Just get into parted and type in unit kB print free for now please, one step at a time. And post the output here.
Sorry this was misunderstood from me ![]()
Number Start End Size File system Name Flags
12.3kB 24.6kB 12.3kB Free Space
1 24.6kB 123kB 98.3kB ALIGN_TO_128K_3
2 123kB 131kB 8.19kB ssd
3 131kB 33686kB 33554kB ext4 persist
4 33686kB 34734kB 1049kB misc
34734kB 67109kB 32375kB Free Space
8 67109kB 276824kB 209715kB ext4 msftdata
9 276824kB 9081717kB 8804893kB msftdata
10 9081717kB 15500050kB 6418334kB msftdata
11 15500050kB 253867590kB 238367539kB msftdata
253867590kB 253868630kB 1040kB Free Space
I have soon removed. Sh
Alright letās start with mkpart keystore 34734kB 35258kB and check with print afterwards if we did get it right this time.
Number Start End Size File system Name Flags 1 24.6kB 123kB 98.3kB ALIGN_TO_128K_3 2 123kB 131kB 8.19kB ssd 3 131kB 33686kB 33554kB ext4 persist 4 33686kB 34734kB 1049kB misc 5 34734kB 35258kB 524kB 8 67109kB 276824kB 209715kB ext4 msftdata 9 276824kB 9081717kB 8804893kB msftdata 10 9081717kB 15500050kB 6418334kB msftdata 11 15500050kB 253867590kB 238367539kB msftdata
We did get the size right this time, but didnāt get a name ![]()
Could you try name 5 keystore please ![]()
While weāre at it mkpart frp 35258kB 35782kB and mkpart metadata ext4 35782kB 67109kB.
Yeah that worked ![]()
5 34734kB 35258kB 524kB keystore
Number Start End Size File system Name Flags 1 24.6kB 123kB 98.3kB ALIGN_TO_128K_3 2 123kB 131kB 8.19kB ssd 3 131kB 33686kB 33554kB ext4 persist 4 33686kB 34734kB 1049kB misc 5 34734kB 35258kB 524kB keystore 6 35258kB 35783kB 524kB frp 7 35783kB 67109kB 31326kB ext4 metadata 8 67109kB 276824kB 209715kB ext4 msftdata 9 276824kB 9081717kB 8804893kB msftdata 10 9081717kB 15500050kB 6418334kB msftdata 11 15500050kB 253867590kB 238367539kB msftdata
Thatās starting to look more like stock again ![]()
Ok, letās do name 8 oempersist and set 8 msftdata off, afterwards delete 9 - 11.
msftdata off, doesnt work, but in help i have the following:
disk_set FLAG STATE change the FLAG on selected device
disk_toggle [FLAG] toggle the state of FLAG on selected
device
set NUMBER FLAG STATE change the FLAG on partition NUMBER
toggle [NUMBER [FLAG]] toggle the state of FLAG on partition
NUMBER
Alright, maybe try toggle 8 msftdata ![]()
Edit: I meant 8 if you copied the code too fast ![]()
Yes that worked. Thanks.
I have removed the 9-11 too.
I have noticed it, no problem ![]()
Great, then letās create mkpart rawdump 276824kB 9082MB and check our progress unit compact print free.
Not sure weāll be able to recreate those last three exactly, since our source isnāt sufficiently detailed enough
Iāll have to check my partition backupsā¦
2 123kB 131kB 8192B ssd
3 131kB 33.7MB 33.6MB ext4 persist
4 33.7MB 34.7MB 1049kB misc
5 34.7MB 35.3MB 524kB keystore
6 35.3MB 35.8MB 524kB frp
7 35.8MB 67.1MB 31.3MB ext4 metadata
8 67.1MB 277MB 210MB ext4 oempersist
9 277MB 9082MB 8805MB rawdump
9082MB 254GB 245GB Free Space
Okay, thank you very much
Didnāt provide more clarity, so letās just go ahead:
mkpart super 9082MB 15524MB and mkpart userdata 15524MB -12.3kB
Hopefully that will get us there ![]()
should i write just so with ā-ā
Yes, that should hopefully give us those 12.3kB free space at the end, stock had.
