Using FP4 since a couple of months and have had this issue since start: Do others experience the same issue as I am or should I create a support ticket:
Text messages that arrive appear on home screen as a notification. When I lock up the phone and go to SMS app, the message is not there. After closing and opening the app and locking and unlocking the phone back and forth the new message appears sometimes and sometimes I have to wait some while, maybe minutes, before it appears. Do other FP4 users have this issue?
Is it the same for both of your SIM cards?
Did you try to clean cache and data of your SMS app (I hope the latter will not delete all old SMS messages)?
Do you use an SD card? If yes, formatted as mobile or internal memory?
Did you try it out with another SMS app?
I receive 99.5% messages on my e-sim, so that’s where the problem is. I have not formatted the sim, that sounds like erasing all messages? And I have not tried another app, which would you recommend? Thanks
So does it only happen for the eSIM or didn’t you try out with hard SIM as you nearly don’t receive SMS for it?
Did you clear SMS app cache?
You might try out “silence” as SMS app.
Haven’t tried hard sim. Now I emptied cache and downloaded silence, will give it a try.
-------- Originalmeddelande --------
PĂĄ 10 maj 2022 07:59, Volker via Fairphone Community Forum < forum@fairphone.com> skrev:
