Slider/Cover for FP2 Selfie Cam
Dear all,
I d like to use a slider/cover for my selfie camera. You ll find lots of them at Amazon and ebay. However, I checked the measures, if any of them fit, but some are too big, or have too small window.
Does anybody of you use a cover, that fits and does not disturb the picture? Any recommendations?
Thanks a lot!
Chris
I’m using the covers from privise.io. They fit very well, i think
Thank you for the info!
Dear all, unfortunatelly, this cover does NOT fit on a FP2. Even if you place it perfectly, you will see shadows in the edges.
