When I try to call from a contact on my home screen, the phone always launches Skype to make the call. If I open the contacts app, I can call using the regular cell phone. When I first used the phone, I accidentally selected “always” when I was asked if I wanted to use skype to make the call. How do I reset it so that skype does not automatically launch from the homescreen when I try to call? Thanks.
Go to Settings > Apps > All > Skype and select “Remove Defaults”.
Worked perfectly. Thanks!
Glad I could help
