found the dimensions of the slim case (eg Fairphone 2 - Slim Case Indigo | Fairphone ):
Abmessungen (Telefon + Case): Länge: 144,5 mm // Breite: 74,5 mm // Tiefe: 10,65 mm
But I can’t find the dimensions of the “usual” case of my/the FP2. Does anbody know it?
Thanks!
webaschtl
Volker
October 19, 2017, 9:35pm
#2
AFAIK dimensions are equal. It’s more an optic change/impression from “usual” to “slim”.
EDIT: well, they’re not exactly the same. More details you’ll find at https://support.fairphone.com/hc/en-us/articles/115001668306-What-kind-of-cases-are-available-for-the-Fairphone-2-
Thanks for the link!
I hoped that the so called slim case would be less thick as the black one. But almost the same thickness: 10.65 mm vs. 11mm
… too thick for using it “in” the Microsoft Universal Mobile Keyboard …
But thanks again!
system
closed
April 20, 2018, 10:31am
#4
