Share de WI-FI with other devices
I can’t share the WI-FI with other devices. The phone is 1 year old, and run perfectly since today…, can somebody hlp me ? The box to share is in blue and the button doesn’t move…
When you tried was wifi enabled? Maybe try to deavtivate
You certainly should be able to turn on hotspot with wifi enabled on the FP4 (I do it routinely on bandwidth-limited satellite-internet wifis because it lets me monitor the bandwidth the connected device is using and cut it off with the press of a button).
As far as I know, you can’t share your WiFi connection while using it. It only works when you’re connected via mobile data connection and then create a WiFi hotspot with your phone for others.
I find the problem. If the option “saving data” was activated, the option “share the conections with other devices” doesn’t run.
