Hi everyone ![]()
Would be nice to have a working SFTPconnection between 2 fairphones.
I tried several SFTPservers and SFTPclients.
Can anybody report from a successfull setup?
Thank you
silvertux
don’t have two Fairphones ![]()
anyway as client from FP5 to MyNotebook@Linux i use:
TotalCommander + SFTP Plugin, is not free/open but is good…
as server i not use before, but now as first try primitive ftpd and connect from FileZilla@NB@Linux to FP5 without problem ![]()
some note to setup:
- set Password (or assign key, don’t try)
- set “Server(s) to be started” to SFTP only, if don’t want also start FTP server
- set “IP to bind to” to your FP5 Wifi IP adress, if don’t want listen to mobile data
Install termux - easy to set up ssh tunnels and sftp connectiond if you know a little Linux.
ok thank you
I try …
