Hi.
I have found a sensor i don’t know. Can somebody sheed some light upon that strange covered sensor A and maybe also name me the B & C?
(Sensor A is normaly covered with a smal rectangle plastic.)
Regards, Novski
Hi.
Zie proximity sensor .
B and C are the proximity and ambient light sensor.
A is maybe the notification LED (when not in the display module itself).
Yes, of course A is the notification Led.
Of course! Now i see it. So the LED has a difusor in front of it… Sweet. That actualy means its possibul to make it lite up stronger…
Thank you!
Novski
