Second charger for FP3 battery?
Hello everybody !
I have to change my present smartphone and i’m looking for a smartphone with a removable battery.
I’m very interested in FP3 with a second battery, but i want to now if i can charge the second battery in the same time i use the phone with the first battery.
Is there any charger that give this possibility ?
Thanks for your answer !
Thank you, AnotherElk !
Your charger is présent at Amazon.fr too.
This is a good solution for my issue.
You might want to give it a go with just the one battery before you buy your second battery. The battery life is amazing!
