Perhaps the advantages of “my” product are that it would be a bit bigger / higher and esp. the possibility of plugging the cable.
But disadvantage that its “back” is a bit too small, its size maybe only the half of a phone? More difficult to touch the phone without the phone immediately tilting backwards. [last sentence: correct translation of deepl? ;)]
I’m afraid to have thrown away my last cassettes at some point after all (although there is still a cassette recorder, somewhere…)
But the mentioned phone stand looks quite good – if it only would be not from Asia and not from Amazon …
Extensive laboratory testing confirms this is compatible with FP1*, FP1U*, FP2, FP3, FP3+ …
Look out for a cassette case with a slim "underlip" (the part that is in front of the phone’s bottom edge in rmf’s photo) – makes the phone stay more upright and relieves pressure from the fragile plastic.
Works fine here with the stand I linked. The phone is about 2.5cm from the desk (other heights are possible) and even with a steep angle (other angles are possible) I can use the phone fine while my left arm rests on the desk.
The stand is placed left of my keyboard, I can even swipe down the Android status bar to handle notifications.
I bought it shorthandly (kurzerhand? ;-)) – and I am fully satiesfied.
Only two deaths I had to die: Made in China and therefore only available via Amazon.
