SD card and 2 user accounts
Unfortunately due to the permissions Shelter gains over the applications in the work profile, I’m hesitant to use it. Judging by this text they have in the app:
By default, Shelter will not ask for any individual permissions. However, once you proceed with the setup process, Shelter will try to set up a Work Profile and hence become the profile manager of said profile. This will grant Shelter an extensive list of permissions inside the profile, comparable to that of a Device Admin, albeit confined to the profile.
Hier ist eine Liste der Permissions von Shelter: https://f-droid.org/de/packages/net.typeblog.shelter/
Hauptproblem für mich sind eher Zweifel, ob das Projekt noch aktiv ist. Allerdings ist das auch bei Alternativen oft die Frage…
At least the Matrix Channel is alive and the dev participating actively, also issues can still be reported.
In the end I didn’t find any solution for this and had to remove the SD card from my phone. Hopefully no other issues appear with the user account switching.
