This is a strange one - my screens suddenly changed their order for no apparent reason (so, if the home screen is 1, the one to its right used to be 2, the next 3, now the order is - 1, 3, 2).
I can’t find a way to change the screen’s location, any suggestions?
Long tap on an empty space on any home screen (or on the little dots that indicate which home screen you are on) to get to the mode where you can do things like add widgets. Then pick up (long tap) a home screen and drag it before or after another.
Thanks! I tried that several times at first and it didn’t work, so I thought I guessed wrong. But now, armed with the knowledge that it should work, I managed to make it do what I want.
__
