Screen rotate not working FP4
hi i am having trouble with my FP4 not being able to screen rotate
i have tried reinstalling the os without success and off courses tried turning screen rotate off and on again many times.
anybody have any idea how to fix this issue
Hi @christian_olsen
I got no fix for it at hand but you could test your gyro sensors (= the sensors for detecting rotation etc) work properly by using the app Phyphox (cost free & ad free from the RWTH university of Aachen/Germany)
It´s a toolset for physical testing and analysis and you can get it either on F-droid or also in the Google Playstore
When you open it select Gyroscope
To start the gyro test you have to click the play button on the top (blue mark on the screenshot).
Then you should be able to see directly the graphs moving whenever you move/rotate the device in (yellow marked section)
Best
DonFnord
thanks i will try that
