I never had a need for a screen protector. The screen om my five year old Sony still looks pristine.
Den tis 29 mars 2022 20:19Goran A via Fairphone Community Forum <forum@fairphone.com> skrev:
Been using Upscreen Hybrid Glass Clear with protection for back cameras and I am mlre than happy. Cristal clear , easy to apply, nice application tools (including ācredit cardā). Thanks for the review!
I always use a screen protector, so I ordered the only one available at the time. Which turned out the privacy screen protector. Waste of money, as per previous posts.
Why doesnāt FP offer just a normal, clear version? Only specials.
Iām happy paying a bit extra to support the FP cause, but I am very disappointed in this.
@Dezponia , thanks for your suggestions! I bought the Savvies glassā¦
Glad it was helpful. Have you got the Savvies Glass? Could you tell us which version you got, and if its truly hard tempered glass as I suspected and they say, or if its a flexible film? I hope it works out great though!
Hi, I received my order and it was really glass.
However, the fit isā¦ Disappointing.
But way better view/screen quality compared to the privacy protector!
Nice to see that its real glass. Which version did you get?
Savvies HD33 Clear/Matte Glass
or
Savvies Full Cover Glass
Maybe the āfull cover glassā version has better coverage or something?
I thought I ordered the full cover on the website/shop, but the order specification state the HD33. That might be the difference indeed
I used the privacy filter on FP3 and I got a lot of scratches on it quite quickly, even from light pressure when I knew there was no hard objects near it I got extra scratches. I ended up removing it because quite frankly the device became less pleasant to use because of the scratches. Same with my work S21 screen protector which came with it. Pressure from nylon (!!) created scratches. Also, while the privacy filter works for left and right side peaking, it doesnāt for up/down (ie. shoulder peaking) it requires more backlight to be used, it sortof defeats the purpose indeed but also it costs more juice and the adaptive brightness no longer works well either. On a Fairphone I have def. quit with screen protectors. The screens themselves are able to withstand scratches better, and should it arise the screen can be replaced for approx 100 EUR (~90 + S&H). With regards to privacy, well its just a given you shouldnāt very private stuff like e.g. bank app if you donāt want a person or camera to see it. I believe in the end we might have to resort to different modes/profiles on a smartphone where certain data remains encrypted until a higher security clearance is given (e.g. PIN instead of fingerprint, or YubiKey FIDO2). Iām kind of surprised this kind of fine grained management isnāt available yet on Android.
I have the same Problem. My Blue light screen Protector broke after 3 days.
If you buy cheap, you buy twice.
I just applied the screen protector with privacy filter, i find the resolution degradation kind of annoying. I would like to point it out in a review on the accessory page but it is not possible. to write one.
I received the Screen Protector from Fairphone through a promotion, so I got it free.
Do you advise me to install it on my device (Fairphone 4), because according to some opinions here, itās not great. Is it a real protection?
Thanks.
The protection is good, only thing I didnāt like was that privacy filter feature.
Hereās the thing: itās basically a bad luck and rare drop protector. Itās nowhere near as strong as the screen glass below. If you can tolerate that some rate small rocks might leave light scratches and that of you have super bad luck in how your phone drops (and the screen doesnāt break with protector on) the screen needs replacing then i recommend going bareback. Sadly thereās no really good screen protector available like you get for flagships. In contrast to flagships you can actually replace the Fairphone screen though.
Just know: modern screen glass is absurdly hardā¦ Likeā¦ Harder than most stones. It will not even get light scratches from normal use.
Once (and only once) I shoved the FP4 (without any protector) in the same pocket where I carry my keys. It stayed there for 30 seconds until I tied my lashes. The scratch was instant. So I wonāt believe these sayings and Iām considering buying a protector. Just because itās ā¬10 to change the protector while itās ā¬100 to change the display.
While thatās obviously the one very much not recommended thing to do itās still kinda bad. Keys should not scratch that glass. Good thing i got that glorified foil on it. Buy in bulk. Youāll want to replace em every so often.
Yeah Iāve managed one very noticeable and a couple very light scratches on my phone screen from keys and/or pocket items so think it may be worth it at least whilst newer to extent life of the screen
An air bubble got under a corner of the Savvies HD33, and somehow it actually shifted up a bit, the camera-cut-out getting half in front of the front camera, so I replaced it.
I messed up, there are some dust specs under it, so looking to buy new ones.
However, at protectionfilms24.com, the only glass Savvies are the HD33, there are no more full cover versions. Only the Brotect Airglass look on the picture to be full cover, (with a top-bar cut out above the camera) and are described as 9H glass.
Does anyone have experience with these Brotects?
The air glass works fine for me.
I first had some which moved too when it becomes warm. Ordered new ones 2 months later and now they fit and hold much better.
Maybe the production process is now more stableā¦?
