Screen protection
Hi all. I saw a lot of persons using a screen protection. However, I read that a real glass protection is useful. someone can tell me if it is necessary with a fairphone and if the basic film would be enough ? Many thanks in advance for your support…
Maybe you’ll find some helpful answers here:
or here:
I am really surprised, that Gorilla-glas looks this way after 4 month of use. This is the center of the screen, maybe 3 x 3 cm.
Spielmops
I thought for the first few moments that your photo shows a black hole.
That’s the black hole inside the FP2, that eats the battery-power, prevents charging and makes the display unusable …
:wink:
