Screen alignment fp5
I have a problem with the screen alignment in the app Instagram. Left edge of the image is not visible.
Really weird.
But the problem surely comes from Instagram itself. As you can see, the bottom bar is well placed. And the fact that you only see it on Instagram is another clue.
In the “Reel” part of the app (4th option in the bottom bar), is the problem also present?
I have the same problem on the start screen of the phone. See top left “Proximus”
Instagram issue is solved by changing the language to English.
Did you by any chance synch all settings from an old phone and/or do you use another launcher?
No I did not. When setting up the phone, I started from a backup from an old phone.
Mistake… it isn’t solved.
This is contradictory:
I guess you took over some setting and this is causing issues
