For a long time I wished to do something in fair trade electronics. Today I finished a big part in an attempt to creating a fairer laptop. It looks like this from the inside:
And like this from the outside:
Used hardware:
- Old laptop that can’t run newer windows versions and also not graphical linux => scrap?
- A used USB OTG hub
- A used USB to DVI adapter
- A used 5V adapter
- A used USB to PS/2 adapter
- A new M.NT68676.2A TFT driver board (the least fair component…)
- Some new hand-soldered components (microcontroller, resistors, etc.)
- Some wire
What can it do now:
- Connect to the USB port of the fairphone (or most other smartphones)
- Type, mouse, display the screen etc, at a resolution of 1200x800 with density 160 (which means: proper scaling for this display). The ‘shift’ key just failed, so I’ll need to fix it…
What are my wishes:
- A working shift key
- Connect to the back USB connector (but it doesn’t work currently in LineageOS) and be able to shift in the phone in the old CD-ROM drive position
- Perhaps a power bank inside for portability
- Dimmable screen
(currently it’s always at 100% brightness)
- Open source driver for Display Link IC (graphics)
- And finally a long shot: a conversion kit for old laptops, with fully fairly sourced components
For the last two points I don’t have enough experience. Perhaps someone here likes the idea and has more experience?
See here for the build log and some old sources. I plan to put them on github when I cleaned them up a bit.
