Now I have tried the app on my FP5 and I could not reproduce the issue in the Coop app, at the local Coop 365 Discount.
When I had scanned some groceries, I tried to have the screen go into stand by both when the apps camera was activated and when it was not. The app survived just fine. I even tried to kill the app manually and it resumed fine, with all of my scanned items on the list.
I noted that the app has a setting to keep the screen on when the camera is activated. That should mitigate the issue.
Why your app did not keep the scanned items, I don’t know. Perhaps you did not have network connectivity in the shop? When I scanned the QR-code at the entrence, the app suggested it should enable the shops wifi - perhaps that would help on that regard?
@erikvaningen as a software developer, the answer is often not clear. Who will fix it is often a game of chicken, but the one who does will only do it after a lot of users has complained.
In our app department, they have about 30 phones and tablets to test the apps on. Development houses with more resources may have many more. It is usually the line of iPhones for the Apple side and on Andreoid several Samsung, OnePlus, Google, Motorola perhaps a few others. But FairPhone is is way way down on the list unless some enthusiastic developer at the right time and place got the budget to buy one.
In the same way FairPhone will probably only fix issues that a enough users has. There are so many quirks and apps that they could hire 100 times the developers they have and still never get to the end of the list.
In this case, a single report from a single cuontry. Can’t even be reproduced by the developers because it only occurs in Denmark. This will probably never be looked at.
I was just happy that my FF5 worked with both the danish 2fa app MitID, drivers license, MobilePay and similar special danish apps that want to scan my pass port via NFC and tries to detect rooted phones.
So what to do: My suggestion is the above: Keep the screen on, try the local wifi, try changing things. I may have different settings than you. I had data saver on, but not battery saver. You can set in the app settings that it should not be killed as easily - I had not done that.
I hope you find something that works, because it is really nice to scan your items yourself.
