Hi there,
I can’t get FP2 to recognize my Sandisk 64GB Class10 sdcard. It’s extfat formatted and runs in my laptop and in a galaxy s4.
An older Samsung 32GB Class6 card however works fine. What can I do? Reformatting? Hopefully not since it’s full of data ;). Seriously, any clues?
Hi @saski,
I use the same sdcard that you have. I had the same problem and had to reformat the sdcard. Right now I don’t know another solution to this problem, sry.
You could maybe move all the data to your computer or a hard drive, then reformat the card in order to keep all the files. (But it’s time-consuming)
Hi, thx for the quick answer. Yeas I was afraid of that so I started backing up. Takes ages but WTH ;). Did you format the sddard with the FP2? If not what Filesystem did you use?
Erased SD with FP2 works fine now
good to hear
This topic was automatically closed after 3 days. New replies are no longer allowed.
