Dear all,
i bought a Fairphone 5 last year because i liked the mission. Repairable, long term support. So i bought one. I was willing not to have top performance, because is dont need it.
Sadly, to say the least, it has been the worst smartphone experience i ever had and thinking i coudld use that to the 2030ies+ gives me nightmares.
My first issue i described in this topic
where no solution could be found. since then the experience has been even more sad.
After a few days the phone does not recognize any charger and needs to be restarted, then it works.
It is impossible to work with, any application i minimize is immediately killed by the OS and needs to be restarted. I actually failed to install an app where i needed to switch to emails to copy the code send via mail, because when i switched back the entire process was killed and had to be restarted. It was impossible without a f****** secondary pc……
The one game i played….impossible to play, anytime i minimize or the screen goes off….hello login procedure.
I tried anything, even going into the dev options of android to tell the OS not to kill everything allways. I had no success.
Then Android Auto. Constant disconnects and connection problems, while the Samsung A54 from my wife has no problems at all in the car.
Spotify: As soon as i open any other application Spotify goes off……about 50% chance on that. So if iam not driving but my phone is connected to the car i cant do anything with it or it will stop the music or completely disconnects.
I am writing this here because the last point is: The support is MISERALBE. neither my contact for the first issue nor anything else ever got an answer.
I tried making it work for a year now and for me a smartphone needs to be one thing: Stable. I dont care about speed or fancy features. And the fairphone 5 fails at this to an extend which i thought not possible in these days.
So whats the possibilties here? Is there a return policy after the amount of time i already tried to make it work or is the money just gone and i by something else?
