Residual glue on replaced screen blocks selfie camera
I successfully changed the broken screen on my FP4. However, the replacement part came with a small piece of tape obstructing the tiny hole in front of the selfie camera. I removed the tape but there is still a tiny amount of glue smeared on the glass, which makes the camera image all blurry. I believe I can clean it off with a q-tip and some solvent, but I am afraid this could damage the screen. Any recommendations on what chemical to use?
Maybe you could start with something like a lens cleaner? You can get them in an opticians or photography shop. It’s toughened glass, if it was mine I’d rub my fingernail over it, but maybe it’s really stuck and could scratch the screen.
