I wish to increase the data limit and set a new warning figure.
I know I have done it previously, but can no longer find where to do it in the settings.
Hi there and welcome
Are you using the standard Fairphone-OS (Android 7)? according this page you should find it under Settings -> Connections -> Data usage
It depends on your OS-version where you can find it.
With android 9 it’s under Settings -> Network & Internet -> Data usage -> Data warning & limit
You can also use the search-function within your settings to find specific settings.
Upon FP2 go to Settings > Wireless & networks > Data usage > tap upon “grey bar” and “set data usage warning” screen appears, then tap in your new limit.
Thanks.
My problem is that my allowance has gone up to 1GB from 505MB. That is the figure I can’t seem to change.
Why can you not change this?
Thanks for your interest. I eventually found what I need under the Billing Cycle menu.
