Hello. I have a FP1 and can’t find where the personal settings are to remove a temporary voicemail message I put on. Can anyone help? I realise this is probably a very simple problem!
Normally a voicemail message located at your provider and not on the phone.
Did you look at your settings of the voicemail at your provider?
Thank you, Lidwien, you’re right - I’ve sorted it now!
