I sent my fairhphone (1st edition) in to have a broken display repaired. During the repair the fairphone was updated to the latest operating stystem, Kola Nut 1.8.5. Since I got it back my battery lifetime is ridiculously short. It’s sometimes less than 12h though my phone is not that much in use.
I check former topics, but still I couldn’t find any solution
wireless is switched off
better battery stats keeps telling me that most of the battery is consumed in deep sleep mode
only app using battery regularly is facebook, but I had this installed previously.
the phone gets quite hot in the upper front parts when I do longer calls
when I charge the phone it says “fully charged” after 20 only minutes.
Please help! I’d like to leave the house for more than just a couple of hours without taking an extra battery with me.
Did you try already several load/unload cycles (3 times from 100%–>0%–>100%) to let the new OS calibrate the battery?
But in addition be aware of the notes of paulakreuzer above!
I removed the battery to perform the spin test, then inserted it back again. Since then I am back to normal battery life time, though I did not completely discharge and recharge or anything else.
What is the result of your spin-test?
If negative: try to let your phone at least drop down to 0%, load in one run to 100% (let FP switch of is not a bad idea).
Please report back, if everything is normal now…
Phone passed the spin test. Like state above it is now working again. I don’t know if it was either the reboot, the removing of the battery or spinning the battery.
