So I want to record a sound to replace the timer ringtone. Does anyone know how I:
- record a sound
- save it as the timer ringtone
thanks
thanks
Settings > Sounds > Advanced
Edited to correct direction to Phone ringtone
See post below . . .
Have fun
In this case it’s
Settings > Sounds > Advanced > Standard alarm sound > +Add alarm
The included Sound Recorder app works just fine for that usecase.
Instead of adding it in the settings, you can also copy the recording from /sdcard/Music/SoundRecord
to /sdcard/Alarms
, /sdcard/Notifications
or /sdcard/Ringtones
(depending on what you want to use it for). That will give you the same result.
thanks guys, that’s been very helpful very quickly,
best wishes
John
The options are the same, I thought that “timer ringtone” meant the timer alarm sound , not phone call ringtone.
Yes you got it right I didn’t read the query correctly
