Re-enter Sim pin issue
Since a couple of weeks, the telephone on my FP3 with the latest June securityupdate disconnects and I need to re-enter the SIM pin. The phone does not reboot. I also checked the Sim card slot. This seems to be an issue that also happened on FP2.
Is anyone else experiencing this?
As a workaround I disabled the pin code on the SIM for now and will keep an eye out for further disconnects.
Hello @johanbove, I may be experiencing the same issue since some weeks, which I am currently observing more closely. Have you found a real solution? Have you contacted Fairphone’s support about this issue? Best regards, Daniel
Same here! Could anyone calrify the issue :)?
Is there a pin for the SIM?
By the way what OS and update are you using, this topic is very old
A post was merged into an existing topic: Selling Fairphone 3+
same here although the last post is more than 2 years old, I still get those re-prompts (build number: 6.A.028.1 )
I have the same issue on my FP3
How old is your SIM and do you use 2 SIM?
