Def not for me, it remains sun on the screen e.g. while taking pictures with the same app
Iāve recently noticed the same thing happen on my device running CalyxOS.
my phone suffers from the dim issue as well. just before starting to type this post it dimmed after I went outside app. 7 or 8 minutes ago. No direct sunlight however, I am sitting in the shadow. what shall I say, it sucks, also as I have ghost touches as wellā¦
Answer from support today:
Dear Steven,
Thanks for your email.
Regarding the issue you mentioned, I will log it and report it to the relevant team for further investigation.
Rest assured that we are doing our best to have this resolved as soon as possible. I kindly ask you to give us more time to investigate this. As soon as we have any news, we will immediately communicate it directly to you.
In the meantime, please remember to keep your phone updated with the latest software. Every update contains improvements that might help with your issue.
We sincerely apologize for the inconvenience and thank you for your understanding. We will not close this ticket until we have a solution for you.
If you have any other questions in the meantime, please let me know, I will be happy to help you further.
Have a lovely day and take care.
Kind regards,
Hi everyone, since I havenāt experienced this issue yet there is a pattern to follow to replicate it?
What I mean is adaptive brightness turned off or on, specific app opened or in use, etc.
Or itās something completely random that canāt be replicated?
For me its a few minutes sun irrespective of what Iām doing and I dont play games. And when it happens in sun, you will notice, because you will not see much.
Others notice during gaming, using duolingo app.
Adaptive brightness on or off doesnt matter.
It happens with Custom ROM so if software related than not OS related. I use FPOS.
I donāt really understand the connection yet either. I got the FP4 last year in the summer. And before I installed Android 12, I never noticed this problem. Now I also notice it when Iām biking, when I check my messages or my route. Since I usually wear sunglasses, itās even more noticeable than before when the display is at 100% brightness, but suddenly itās hard to see anything. I did the same things with Android 11 and, as I said, I never noticed it.
For me it mostly happens when Iām driving on a sunny day and running a navigation while charging the phone. It sometimes also happens without charging or with different apps, but not that often. So in my case itās usually triggered by a combination of sunlight and heat.
Yes, itās definitely a new issue which came with Android 12.
Well, at first glance it would seem to be related to Fairphoneās version of Android12, but there are people using custom OSes (I remember mentions of Lineage and Calyx, there might be others, Iām too lazy to sift through those 167 posts).
So, itās not Fairphoneās A12 version. But then again the problem seems to have appeared the exact same time Fairphone released their A12 upgrade.
Could it be tied to the Android version (some A12 driver not playing nice with FP4ās hardware)?
Could everybody having this issue and using a custom ROM please state which Android version they run?
Iām using Lineage OS with Android 13 and I also have this effect.
Custom ROMs usually use Fairphoneās proprietary blobs, so this bug can very easily be contained in them.
Sure. But then again people with custom ROMs having had Android 12 before Fairphone released its own Android 12 didnāt state any similar problems (AFAIK).
Did those ROMs get updated with Fairphoneās buggy drivers? (genuine question)
I donāt know how Android manages its drivers, but I would assume (maybe wrongly) that Fairphoneās OS is pretty much vanilla Android, using manufacturer-supplied drivers. They donāt seem to have the infrastructure to make their own.
So, where/when/how was the problem introduced?
I have this issue and I am running CalyxOS 4.9.4 (Android 13).
The same form and conditions apply to me.
Same problem here, since the Android 12 update. Sometimes I notice it happens inside my house, but most of the time outside.
Did those ROMs get updated with Fairphoneās buggy drivers? (genuine question)I donāt know how Android manages its drivers, but I would assume (maybe wrongly) that Fairphoneās OS is pretty much vanilla Android, using manufacturer-supplied drivers. They donāt seem to have the infrastructure to make their own.
That really seems to be the main problem. If it is in other versions of the operating system, I canāt explain it any other way. If these drivers are used in other ROMs, this is indeed the only logical connection. This would also be comparable to the Bluetooth audio bug, which also exists in other ROMs.
for me it is happening inside the house as well. I guess there is a certain bias in recognizing when it happens as inside you might not even notice it - opposite to outside and even more in direct sunlight. so I doubt that heating up or the sensing of very bright surroundings is the trigger for the issue.
Thanks everyone.
Today I have been able to reproduce the issue.
Outside with direct sunlight, after some minutes, the brightness decreased at almost no readable level.
Tried inside with a direct light source on the sensor to check if itās some bug with the light sensor, bit didnāt happen.
It seems like an overheating protection that as some point itās triggered, but not sure.
Tomorrow I will try to make a logcat with adb shell and my laptop while outside with direct sunlight.
I have the exact same issue! I that it was something I only had. It happens the same to me, after a while it randomly dims and I canāt get it back to the maximum brightness.
That doesnāt necessarily mean anything, because unless you have some WWII anti-aircraft searchlights, the sun is quite a lot brighterā¦
You should try to isolate the factors, i.e. try direct sunlight in a cold environment, normal (sunny, hot) sunshine conditions but not at full brightness (a sliver of neutral filter on brightness sensor), strong lamp and phone getting hotter (for instance charging), and so onā¦
