Since the last update, the quick access does not have the button for location. I like to dismiss location most of the time and now, I have to go in settings, scroll down… I want to be able to dismiss location easily. Why is it gone? Can I choose what is on my scroll down quick access menu?
THANK YOU!
Yes. Pull down the quick settings menu twice and tap the pencil icon.
Thank you very much!
