Hello, I’m wondering if the smart assistants are integrated into the devices or how that works. Is the,
Smart assistants
section on the Fairbuds XL specifications just announcing which smart assistants it works with?
Smart assistants
I have never used any smart assistants, but I’m pretty sure that it runs on the phone (or connected device), and the fairbuds just triggers the assistant of the phone, which it does by sending a standardized button press event. and which smart assistant is triggered depends on what did you select on the phone.
it is probably just a short list of examples for the less technically inclined
