Problems with setup alarm FP2
Before the upgrade to android 6 i could set my wake up call but after the upgrade i can’t see it anymore on my screen. Anyone got the same problem and how can i fix it?
Use the clock app or widget to set alarms.
Either long press the background and select widget to find different clock widgets you can add to the home screen or simply add the clock itself. The in the clock app, you can set your alarm as usual.
Hello Ben,
Thx for the tip
Tom Gilson
