Problems editing notes in Evernote
From the new update I can’t edit notes in Evernote… Somebody else has the same problem…?
It seems that the update didn’t solve the bug of the Privacy Impact feature.
So re-enable Privacy Impact by unticking the option found at:
Settings > Sound & Notifications > Privacy Impact
Thanks, the problem is solved…
Thank you for your fast answer!!!
I’m very proud of my fairphone 2!!
Enviado desde Yahoo Mail con Android
