After the update for my fair phone, the Smart launcher app interferes with all the functions of the phone. Neither the restart nor the restoration of the app led to a solution. Now I want to uninstall the app to be able to use my phone again, but this is neither possible under “Settings - Apps” nor via the play store, because I have no access to it, like to all other functions. How can I fix the problem?
Which Fairphone model do you have?
How is it not possible to uninstall the app via Settings -> Apps? Is the uninstall button greyed out or is there another reason? Any error message?
It could be the app is registered as a device admin app. You could then revoke that under Settings -> Security and then uninstall the app.
Sprichst du Deutsch?
Ja.
Welches Fairphone Modell hast du?
Was genau funktioniert nicht wenn du die App in Einstellungen -> Apps deinstallieren willst?
Kommt eine Fehlermeldung?
