Problems after Android 13 update
Since in downloaded the Android 13 my phone is restarting itself whenever it wants.
Sometimes not for hours an than several times in a few minutes.
And some of my apps like the google calendar can’t be opened over the app cause it says the app isn’t installed. I can’t deinstall it and in the Playstore it says it’s downloaded.
These are the problems so far.
I don’t know will add to that in the next days, hopefully nothing.
Try turning of 5G that should hjelp. It did for me.
Someone moved your question to the FP4 category most likely because you added FP4 to your account, can you confirm your question is about a FP4?
