In order to get more storage I have to update from Caju to Pre update Kola Nut 1.8.7
I deleted apps, pictures etc, but nothing happens!
What do I wrong? Pleade advise
I assume what you want to do is the storage upgrade. The dilemma is that right now you most likely haven’t got enough internal storage left to even accomodate the storage upgrade nor the update to 1.8.7. I recommend that you do the following (in chronological order):
You might have to find the instructions for steps 1, 3 and 4 yourself if the links I provided above don’t lead you directly to the individual instructions.
