Poll + general discussion: who got Android 10 Update on their FP3 & first impressions
DON’T flash that version, I did it because I am quite stupid and new to flashing thing into my phone and boy it got me in trouble, see my topic as @Johannes mentioned.
Another issue with gesture navigation enabled… Is there no way to go back in Chrome?
For me Android 10 is working well, and it seems to be a bit more responsive. There is one thing that is annoying, and it is right on the home screen. My weather online widget cannot be expanded over the Day and time
old one and here Android 10 . Any suggestions?
Yes, the zip file seems broken even though the sha256 is correct:
    testing: system.img               bad CRC 22cbcb73  (should be 5197923a)
At least one error was detected in FP3-REL-Q-3.A.0033-20200815.010936-user-fastbootimage.zip.
I removed the download link in my post.
Swiping from the left-bottom into the screen doesn’t work as expected? Do you only have the problem with Chrome?
Wont install (wait for /e/ 10)
That works @Sideness, thanks. I didn’t know about those gestures in Chrome. For others that are struggling: it’s the side edge of the screen. Forward also works on the right side.
Got it last night.
Still getting used to the interface.
Don’t like the new wallpapers. Does anyone know where I can get some wallpapers in solid colours.
I helped translating an app called Walpy
which has all kinds of wallpapers from Unsplash. Maybe you can find something there that pleases your eye.
I’m on HollandsNieuwe, which is the Vodafone network. I just switch of my SIM and then I can update over WiFi.
Hmm, this is the security update for July… So not Android 10.
KPN user here , and still no update here yett
The July security update is included in your Android 10 upgrade download.
Android 10 also has security patchlevel of July. And I’ve seen some (french) user posting a screenshow of their updater that didn’t say anything about Android 10.
But if the buildnumber is A.0033 and the download size larger than 1 GB it is Android 10 even if the updater doesn’t say so.
You’re right, I’m now on Android 10!
Get a grasp of the concept of ergonomics. That was easy. SCNR
I noticed that there is a slightly different font with the update. It’s a bit thicker now.
this is the old one:
Blockquote
I tried this, too. I even removed my sim card, but there’s still no update.
Maybe, that’s why.
So, you might have to be a bit patient; which might be a good thing, as first small glitches might be straightend out, before you get your update.
Edit:
If you have access to another SIM card from another provider switching cards (just for the update) might do the trick.
I am on Vodafone UK. I checked for the update and it said I was up to date, even though I’ve had no updates since February. I switched to my second sim for data (on the EE network) and checked again and there was the Android 10 update immediately available. It is downloading now over wifi. So there is clearly a continuing problem with updating with a Vodafone sim active for data.
