I’ve had a problem last few months where I couldn’t update apps, which locked me out of a few of them. I also couldn’t download any new ones. All via the Google Play Store.
I’ve tried many solutions, but my most recent one has all but bricked my phone. I was allowed to download a select few apps - browser and such - but mostly, I have nothing. Any solutions?
This sounds rather strange, we’ll probably need more info to solve the problem.
Could you post the values you see for the following settings:
Settings > About phone > Build number
Settings > Security > Device admin apps
Have you experienced any problems with your Google account?
You might also like to briefly describe the solutions you’ve tried unsuccessfully, this will save time for everyone and may provide us with incidental information.
Does your phone have a SD (memory) card and if so, which option did you choose for the way it’s used (internal expansion or as portable)?
Settings > Storage
Is your Wi-Fi connection good?
Have you tried doing the updates one app at a time?
Have to think a bit more then. In the mean time, make sure your phone is properly backed up, it may end up with a reset. No big deal if the backup is OK.
Do you remember having disabled any Google services?
Yes it would have been helpful to mention that you’d already done a factory reset
As far as I can see there remain two possible sources for the problem: an error with the OS software itself (including Play Store software), or a hardware problem.
Do you remember a particular event some months ago (from your own indications) after which you started to experience these problems and which might be the cause? Physical damage? An OS update that went badly?
Have you been in touch with Fairphone official support over this?
Is the phone still under guarantee (bought less than 2 years ago)? If so it’s really important to #contactsupport immediately, to benefit from that.
Have you seen any other malfunctions that might be due to faulty hardware (lost or damaged files for instance)?
In the event of damaged OS have you any experience with ADB?
I would also recommend enlisting help on this, either from a local #fairphoneangel if there’s one near you, or else you might find a good repair shop or send the phone in for a repair estimate (if no longer under guarantee).
