Phone not recognized by Linux after OpenOS install
I recently installed OpenOS and so far so good, except for the fact that I am not getting any USB options when I plug the phone to my computer. With the Google version of Android I would get the options using the same cable and computer, so I assume it is related to the install of the new OS.
I tried using jmtpfs, but the output was: “No mtp devices found.”
Any tips are appreciated
Here’s something you can try on the phone …
If developer settings aren’t shown yet in your settings, go to Settings - About phone and continuously tap on the Build number a few times until it says you are a developer now. Developer settings will then be visible at the bottom of the settings.
Thanks @AnotherElk that did the trick.
It’s a shame to see the bug from the previous OS is still present, where choosing ‘charge’ only charges the phone for a few seconds, and the only option that really charges the phone is the ‘Midi’ option.
But the file transfer option works now, so problem solved. Thanks!
To avoid duplicate topics please continue in the other thread if desired.
