Phone got wet - touch function not working
Hi all, managed to drop my FP2 down the toilet (don’t ask!), immediately took it apart (inc. modules) and dried as best I could, wiping contacts with acetone, the next day it seemed to work fine (amazingly!) until the evening when touch function went on the screen - it’s clearly getting some kind of inputs as it jumps around/‘fixes’ on certain points of the screen (ie. looks like it’s being pressed when it’s not), any advice?? Notifications still pop up etc & side buttons still work, I’ve left in a warm place for 48 hours disassembled, so it must be dry by now…? Would it be a replacement screen or more likely an issue with motherboard/contacts? Many thanks in advance!
Please check out the #waterwiki. You’ll find all the info you need there.
Thank you! Hope I didn’t turn on again too soon :frowning:
They say rice can make it work again as it absorb the water in it I’ll also suggest #waterwiki. Hope this helps for future reader.
Rice can also damage the phone even further, as can be read in the mentioned waterwiki .
