Yesterday I took out my phone and noticed it had been rebooted. I might have accidentally pressed the power button in my pocket, it happens sometimes. When trying to enter the pin I noticed the screen was unresponsive. I pressed the power button and rebooted the phone. I could now enter the pin and log in on my phone. Noticed I had 1% battery left. After a minute or so, the screen became unresponsive again, and had freezed. I recharged the phone, then I rebooted it once again, and the same thing still happened. The phone works for a couple of minutes and then freezes. I have also removed and reinserted the battery to see if that helps, but the same thing happens anywayâŚ
Interestingly, when I press the power button, the dialog box that appears works, some of the timesâŚ
Another detail: When I use the power button to lock the phone and then press it again unlock the phone, I come back to the frozen screen.
Also, when I let the screen be on for a while a dialog box appears that says: âFairphone Launcher 3 isnât responding. Do you want to close it?â. I press âokâ but when the dialog box disappears nothing happens.
Hi, i have exactly the same problem. This started happening after I updated tp 1.9.3. Have you also updated to the newest version?
Yes, it started happening to me after the latest update too. Though not immediately after. I think I had the latest update for a few days before it started happening.
Happened to my daughter, also after an update. Fixed it by foricing another update â it took multiple tries to finish the download and install the update. Seems to be working now.
Could you explain what you mean by forcing another update? How do i do that?
It happened to me as well today, would love to get the answer.
hello,
I have exactly the same problem since last update (actually not just after but a few time afterâŚ) and I guess it comes from Hiccut. Saddelly, I donât manage to remove it.
I have put my phone on safe mode then I can use it âas a phoneâ but I can use apps that Iâve downloaded all by myself.
But it is not a solution, please help us !!!
If you open the Updater app and go to Advanced Mode you should be able to re-apply the update.
Exactly the same problem here! Very annoying, basically makes your phone impossible to use.
I will try to install it again and let you guys know if it worked. Thanks.
Have exactly the same problems in my girlfriends phone, i just told her to do the update manually. if this wonât work, can it be an option to install stock android? We have that phone for a year now and there seems to be a lot of software issues, smaller or bigger. Would be great if stock android can fix those
Dear all, I tried to install the latest update again several times earlier this week but this didnât work; it simply took too long to download the update again⌠the phone always froze before finishing the download.
After that I found out how to reboot in safe-mode. In safe-mode, I did successfully the most recent update. Next to this, I deleted all my recently installed apps. Later, back in normal mode, nothing changed: my phone still freezes after every few minutes.
Yesterday, I contacted Fairphone via telephone. The guy was friendly and helpful, but no real solution was offered: just advice on some procedures + reading out info from this forum thread⌠Plus, the suggestion to do a factory reset. But this seems overdone: all was working until the latest update. I prefer to just install an older Fairphone software update + I canât back-up my phone now (and do the factory reset) because my phone freezes after a minute or 2 every time.
I sincerely hope that Fairphone will urgently look into this matter. Not being able to use my phone for almost a week now. Have switched back to iPhone 4 to at least be able to surf the internet every now and thenâŚ
I have the exact same problem, did anyone find a solution?
I tried to get the downgrade, but I canât get it installed.
I got pretty far tho: rebooted in safe mode, downloaded the old verison als .zip file, launched it via the updater app, pressed install, reboot⌠and then I got an error.
I tried to find instructions on how to proceed but I canât find the solution just yet (for example, here: How can I downgrade the fairphone OS to an old version?).
If anyone succeeds in installing an older OS version, please let me know how you did it and if it worked. Thanks!!
My phone is working now. When I looked for updates in settings I found that the latest update was not installed. It said I was using 1.8.1 and not 1.9.3 (which is the latest update). I thought I had the latest update because I had updated fairly recently. Anyway, I managed to download and install that update and since then my phone has been workingâŚ
Mine is still the same, I have tried everything suggested so far and still not working. I really need a solution, I have the FP on safe mode but I need access to some apps. Any other ideas?
thanks!
For us the solution was to deinstall the Facebook App. Works fine for an hour now
Deinstalling Facebook App worked for me too, thanks a lot for the tip @rainer1717!!!
Desinstalling facebook work for me also. thx thx
