Phone fell, now screen stays dark
My FP2 fell - not from a couple of feet. It landed on carpet.
When I first turn it on, I get snow on the screen, and then it goes dark. I can call the phone and it will ring, but I cannot answer a call because the screen is dark and unresponsive.
Does anyone have any ideas about what might have happened and how I can fix it?
Thank you.
It might be worth following procedure here to make sure that nothing has been displaced:https://support.fairphone.com/hc/en-us/articles/214834823-How-to-remove-the-display-module-from-the-Fairphone-2
Hello
Thank you very much for this. I’ve now taken it apart and put it back
together again - unfortunately the issue still remains. :frowning:
I think I will just have to wait until the display module is available
again to purchase as a spare…
Seems like at vireo.de they have screens in stock:
https://www.vireo.de/fairphone/zubehoer/8627/fairphone-2-display-modul
Maybe that helps.
And you can always try contacting a Fairphone Angel in person to check for some testing or further advice.
The nearest angel can be located on the Community Map:
Ordered!
Thank you very much!
Carol
